Problem: When I print a layout tab the model space objects print in color, and the paperspace objects in black. I would like everything in black.
Wasn't having this problem before. I use a work created ctb file used for printing black (monochrome). When I open the ctb file it looks ok.
It seems the problem is the file because I have used the same ctb file with other drawings and it is ok. Has anyone else seen this and have
a solution? I jump from 2015 to 2017 using the same ctb (if that has anything to do with it).
