So I just realized I should not be scared off by VL-*, the long scarey names where single functions!
VL is a lot easier than messing with dxf codes and entity lists.
I have started an AutoLISP 101 class that covers that legacy methods, but soon enough I will present classes on VisualLISP too.
I am just stepping through that in order.
P=
AutomateCAD
I've always been a fan of David M. Stein's book, "The Visual LISP Developer's Bible" personally:
https://www.theswamp.org/index.php?topic=39403.0
Originally Posted by BlackBox on September 08, 2011
Cheers
Computer Specs:
As .LSP files are just plain text, VLIDE is not required, although it is the easiest IDE to use for LISP as a result of the integrated help (unless you're using Civil 3D, as non-ActiveX functions are not included in any help search; only works in vanilla AutoCAD), apropos, etc.
You can use Notepad++ (or other) if you prefer.
Computer Specs:
2nd the Vlisp bible use, there are other good references as well Ronaldo Togores has a number of Kindle books and very cheap like $8 each.
I find most LISP programming books are confusing...
I like the Rawls and Hagen book, but it has errors in it.
I like learning it on my own and occasionally reading a reference.
2 cents
AutomateCAD
David's book is the single best I've read to date; very clear, concise, logical, and it even made it easier to learn C# when reading Andrew Troelsen (some years later).
If you're looking to be a good LISP developer, or instructor, you'd do well to read David's latest book... Money well spent.
Cheers
[Edit] - Heck, David's book helped me to realize some of my ability at not just LISP, but language and coding generally. So much so, that a now former AUGI VP was willing to invite me to become a Mod here.
Perhaps that will help to clarify my sentimental bias. Haha
Computer Specs:
I have taught LISP at University Level before and found (like many instructors) that I found the references lacking.
I also have taught at AU for more than 15 years and found most classes do not teach the most important parts.
I also have very specific programming priorities that those books do not cover the way I would teach them.
The most important is good documentation, variable naming, function naming and error trapping....
I have never seen any LISP books teach that as I would.
Peter
AutomateCAD
Computer Specs:
