Thread: Door Swing to IFC
    2012-10
    2
    Default Door Swing to IFC
    Hi,
    I am encountering issues with door swings when exported to IFC. I use in general the subcategory "Plan Swing" to create a symbolic line for the swing:
    Lately I imported some families from a dutch library and the family's are drawn upside down:
    in revit the swings are presented correctly (I used flip controls for the doorplacement):
    the left two doors are the first family and the right two ones are the second and upside down family.
    But when I export this model to IFC, I get this:
    As you see the right two doors do have a wrong mirorred swing presentation while the geometry of the door is still as drawed in revit.
    When I override the the ifc parameter "operation" than i can flip the Hand but the facing is still mirrored (on the other side of the wall).
    I use the ifc exporter from sourceforge and tried revit 2017 and 2018, both do have the same problem.
    Is this solvable without redrawing all the families?
    All AUGI, all the time Alex Page's Avatar
    2004-03
    Wellington, New Zealand
    822
    Default Re: Door Swing to IFC
    Unfortunately not: Al your doors have to be built with the Swing facing upwards (in the family editor) for them to be correct within IFC.
    More about it here:
    http://www.buildingsmart-tech.org/if...al/ifcdoor.htm
    and summary screenshot of relevant part:
    We managed to rotate 180 degress everything in the family edeitor without breaking the door
  1. 2011: changing door swing in a door legend
    By felix.246611 in forum Revit Architecture - Tips & Tricks
    Last Post: 2012-06-04, 11:33 PM
  2. Door Swing Disappears when door is flipped
    By dannycerezo in forum Revit Architecture - General
    Last Post: 2010-02-06, 09:40 PM
  3. Door family w/ curved swing new and straight swing existing
    By ericsson in forum Revit Architecture - General
    Last Post: 2007-12-19, 04:02 PM
  4. Parametric Door Swing w/ Nested Door Slab
    By Recdiver in forum Revit Architecture - Families
    Last Post: 2007-05-11, 08:07 PM
  5. Attaching a door plan swing to the door leaf?
    By patricks in forum Revit Architecture - Families
    Last Post: 2005-03-24, 07:56 PM
