I'm looking at replacing my old single monitor with either dual 24" monitors or a single 29" ultrawide monitor that has picture in picture mode. Has anyone used an ultrawide monitor and if so what was your experience?
I've got 1 29" and 2 24", and am not as impressed as I thought I would be with the 29". Wider, but not as tall as the 24s. 2560X1080 vs 1820x1280.
Given my druthers i'd probably go with 3 27 inchers at 2560X1440. heck, they are only $700 ea.
To add to this discussion, has anybody seen autocad on a curved ultrawide display? I currently run triple head 27" displays but am looking for higher resolution so I have been kicking around moving to double 34" ultrawide monitors at 1440p. I haven't found many opinions about whether curved display is an issue or not. Some say you get used to it, other say absolutely unusable. Part of me thinks its important that the monitors are sitting at the correct elevation.
Hi,
I've been using a 34" flat Ultrawide 3440x1440 monitor with 2 23" for more than two years, now.
It's really pleasant to me to have a wider working window for Revit or C3D either you split screen with different views or not.
Regards,
