Thread: block scale issue
    2010-05
    94
    Default block scale issue
    not sure how it happened but some of my cad dwgs when i insert a standard block that ive always inserted in the past.. i have to scale it up 12 times for it to get to its standard size. i assume there is a setting in that specific cad dwgs that fixes that. please let me know what that setting/s may be
    thank you!
    2005-06
    in the upper right corner
    3,507
    Default Re: block scale issue
    Quote Originally Posted by cadmaster77 View Post
    thank you!
    Check your insert block variables:
    INSUNITS
    INSUNITSDEFTARGET
    INSUNITSDEFSOURCE
    Make them all zero and you may be all set.
    (look into the 'help menu on these topics, it explains what they control)
    Check the source block drawing and the drawing you're inserting into.
  1. 2016: Civil 3D Structure Profile Block display scale as drawing scale
    By Trevor Deleske in forum AutoCAD Civil 3D - Profiles
    Last Post: 2017-01-27, 01:12 AM
  2. Get current drawing scale, then insert block via that scale
    By U.Rackharrow in forum VBA/COM Interop
    Last Post: 2016-12-09, 03:18 PM
  3. 2015: Scale Parameter in a Title block with multiple scale views
    By david_peterson in forum Revit Architecture - General
    Last Post: 2015-09-18, 10:12 AM
  4. Annotate Graphic Scale Block by Viewport scale
    By msmith.109036 in forum AutoCAD Customization
    Last Post: 2013-11-12, 05:58 PM
  5. Replies: 0
    Last Post: 2013-11-08, 05:29 PM
