Thread: Default resizable RETURN/SUPPLY Grilles needed!
    2017-07
    Default Default resizable RETURN/SUPPLY Grilles needed!
    Hi everyone! I am very new to Revit MEP and I've been trying to learn it from researching online and CADLearning witch is very good course but sometime you get stuck on something and no tutorial can help you! I would like to ask you about an issue with return/exhaust grilles that I've been having . Iam currently working on my first project witch is a VRV Layout and i need to place some grilles. The problem is that REVIT has many default resizable SUPPLY grilles but I can not find any resizable RETURN or EXHAUST (not HOSTED and not mounted). It has only some standard sizes and I need to customize the size as I have 3 different size return grilles in my project. Am I doing something wrong? Can someone tell me where I can find any? I already looked in BIMOBJECT and didn't find any. Any help would be appreciated!
    2001-12
    St. Louis
    5,408
    Default Re: Default resizable RETURN/SUPPLY Grilles needed!
    Quote Originally Posted by ChatziEvgenia View Post
    Hi there! Congrats on making your first post. I moved your question from the BIM Management forum to this one (Revit MEP - Families) as I believe it will be better served here.
    Cheers.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2017-07
    Quote Originally Posted by Wanderer View Post
    Cheers.
    Thank you
    2017-06
    Little Rock, AR
    5
    There is a TON of families that you can find on Autodesk seek. But the simplest family fix I would recommend is if you have a supply grille you like, open the family editor. And select the duct connector component, and on the properties panel change it to either return or exhaust and re save the family with a new name and load t into your project. This will give you an exact copy of the supply grilles but with the capabilities of exhausting and returning calculations.
    When you do this you will need to make sure that you update the identity data for scheduling of the new grille(s).
  1. 2017: Not getting flowrates for AHU supply and return main ducts
    By Arun.K.Mathews in forum Revit MEP - General
    Last Post: 2017-02-25, 04:57 PM
  2. Return Air System Prints Laighter than Supply
    By gvluisi in forum Revit MEP - General
    Last Post: 2010-06-29, 12:40 PM
  3. return / exhaust grilles
    By dhagenbuch in forum AMEP General
    Last Post: 2009-12-09, 07:57 PM
  4. Supply Air - Return Air Rendering
    By mjward1 in forum Revit - Rendering
    Last Post: 2008-11-12, 03:46 PM
  5. Hydronic Return/Supply chiller
    By alan.jackson in forum Revit MEP - General
    Last Post: 2007-08-10, 03:46 PM
