Here is a place to start.
The syntax is
(TitleBlockValue strBlockname strTagString)
and it will return the textstring value of the first attribute with the specified tagstring in the first instance of the strBlockName block
P=
;___________________________________________________________________________________________________________|
; Written By: Peter Jamtgaard copyright 2017 All Rights Reserved
; Abstract: This set of functions are designed to get an attribute textstring from the first instance of a
; (or selected) block reference i
; Command Line Function Header List
;* C:TitleBlockValue
;* Command Line Function to get a value from a block reference and a tagstring (test function)
; General Function Header List
; Function, Arguments and Description
;* (AttributeSublists objBlockReference)
;* Function to create a list of sublists from a block reference of its attribute tagstring, textstring and handle
;* (AttributeTextString objSelection strTagString)
;* Function to get a textstring value from a block reference and a tagstring
;* (TitleBlockValue strBlockname strTagString)
;* Function to get a value from the first instance of a block reference
;$ End Header
; Command line Function to get an attribute value from a selected block and entered attribute tagstring.
(defun C:TitleBlockValue (/ entSelection objSelection ssSelections strTagString)
(if (and (princ "\nSelect Title Block: ")
(setq ssSelections (ssget ":S:E" (list (cons 0 "INSERT")(cons 66 1))))
(setq strTagString (getstring "\nEnter TagString: "))
(setq entSelection (ssname ssSelections 0))
(setq objSelection (vlax-ename->vla-object entSelection))
; Function to create a list of sublists from a block reference of its attribute tagstring, textstring and handle
(defun AttributeSublists (objBlockReference / lstAttributes objAttribute)
(if (and (vlax-method-applicable-p objBlockReference "getattributes")
(setq lstAttributes (vlax-invoke objBlockReference "getattributes"))
(setq lstOfSublists (mapcar '(lambda (objAttribute)(list (strcase (vla-get-tagstring objAttribute))
(vla-get-textstring objAttribute)
(vla-get-handle objAttribute)
lstAttributes
; Function to get a textstring value from a block reference and a tagstring
(defun AttributeTextString (objSelection strTagString)
(if (setq lstOfSublists (AttributeSublists objSelection))
(cadr (assoc (strcase strTagString) lstOfSublists))
; Function to get a value from the first instance of a block reference
(defun TitleBlockValue (strBlockname strTagString / entSelection objSelection ssSelections)
(if (and (setq ssSelections (ssget "x" (list (cons 2 strBlockName)(cons 66 1))))
(princ "!")
(vl-load-com)
