I have been searching for the last few weeks for a solution to my problem, but have not found my problem.
My problem is with PDF's made from the DWGtoPDF.pc3 file, that has an attached PDF on the sheet, but only PDF's with attached PDF's. If the PDF is converted to a JPG the final PDF prints fine.
I know I have found a work around, but I'd like to not have worry about it. I was also told that it was our .ctb file, I have tested that, it doesn't matter what .ctb file is used. We get the same results.
The line weights on the final file PDF usually print darker then normal.
I'm attaching PDF examples. The two sheets are with in the DWG file and the floor plans should match in line weight.
Thanks for any help and solutions anyone might have.
If you have any questions about anything please let me know.
Thank you,
Matt
