Results 1 to 7 of 7
Thread: VBA/Lisp to pick XY values corresponding to the numbers
    2011-07
    22
    Default VBA/Lisp to pick XY values corresponding to the numbers
    Hi,
    We have a cable routing drawing where we provide nodes/points and assign address to each points. The nodes are in blocks and the address are plain texts.
    As of now we manually pick the coordinates of each node along with the adress. Is there a program that shall simply the task or can we make the address as attributes/blocks so that the work is made simpler.
    Requesting support or any other method to follow is highly appreciated.
    Cheers,
    Rajesh
    2004-01
    4
    Default Re: VBA/Lisp to pick XY values corresponding to the numbers
    Create a FIELD who displayed the coordinates of Insert-Basepoint-Position?
    (without open the dwg, your Post sounds like this)
    Its also possible to pre-define this Field in ATTDEF as Value.
    Search for: Autocad field coordinates
    Example in this kind https://www.google.de/url?q=https://...DO1pruPE9vSF2A
    2011-07
    22
    Hi, thanks for your reply.
    My requirement is something similar to the one you have referred, but instead of coordinates being displayed we have node markings & require the coordinates along with the node numbers.
    Thanks.
    Rajesh
    2005-06
    CORDOBA-ARGENTINA
    275
    please explain how do you want engage blocks with reference or adres .
    if possible do a before and after sample
    2011-07
    22
    Hi,
    Let me brief the steps that we follow to pick the coordinates.
    In general we use this for preparing the cable routing document.
    1. Draw poly lines (in cable contour layer ).
    2. At required places we place nodes ( refer attached image ) and assign node numbers.
    3. Except Junction node, others will have two or three node numbers attached to it.
    4. Once all these are done, we manually pick the X/Y values and update them in a excel sheet.
    So like this, we have many nodes and node numbers assigned to them. Intention is to have a lisp that shall automatically export the values of each node in a excel file ( refer attached sample).
    Thanks.
    Rajesh
    2003-07
    555
    Whilst this is not exactly what you want but should point you in the right direction.
    http://www.cadtutor.net/forum/showth...ction-to-Excel
    2011-07
    22
    Hi, Will check this and revert. thanks for the suggestion.
    Regards,
    Rajesh
  1. Need a lisp that can extract the numbers from selected Text
    By brahmanandam.thadikonda762224 in forum AutoLISP
    Last Post: 2016-12-10, 11:04 PM
  2. lisp routine for page numbers in Autocadd
    By mrmwood568385774 in forum AutoLISP
    Last Post: 2013-08-22, 06:29 PM
  3. Need LISP function to pick layer on the fly
    By tatriest in forum AutoLISP
    Last Post: 2010-02-19, 02:52 PM
  4. Replies: 4
    Last Post: 2006-07-14, 08:34 PM
  5. Lisp won't return pick box to my costum setting?
    By Hammer.John.J in forum AutoLISP
    Last Post: 2006-01-07, 12:47 AM
