Thread: windows 10 plotting
    2016-06
    Default windows 10 plotting
    I have AutoCAD civil 3d, and adobe pro, but when I go to plot a PDF, the PDF opens in internet explorer and I don't understand why. I've made adobe my default PDF viewer and disabled all of the internet explorer add-ons. My company is slowly making the switch to windows 10 and I think that it's causing this problem but I'm not sure.
    Tallahassee, FL
    2,856
    Default Re: windows 10 plotting
    What version of Civil 3D are you using? Is it 32-bit or 64-bit?
    This may help: https://forums.adobe.com/thread/1086608
    Tom Beauford P.S.M. - Civil 2018 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering
    Ph# (850)606-1516 Home Page
    Houston
    9,395
    If you are on Windows 10, it's probably hijacking your "default" PDF application.
    Are you sure it isn't Edge that is opening, not IE?
    Programming Moderator BlackBox's Avatar
    5,243
    In File Explorer, right click a .PDF file, select Properties menu item, on General tab to the right of 'Open with:' click the Change button, select Adobe Acrobat (or your preferred PDF application), click OK button, then click the OK button on the file properties dialog.
    If your firm is standardized on using Acrobat (or other) for PDFs, your IT Admin can also set the default PDF file association using Group Policy (GPO): http://theitbros.com/set-default-fil...-group-policy/
    Cheers
    Dell Precision 3620, Core i7-7700K 4.2GHz, 32GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
  1. 2013: Plotting to pdf in windows 7
    By vanderloo5 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2012-10-26, 05:43 PM
  2. Windows 7 - Windows 7 Autocad 2012 Plotting Issue
    By richelleharp in forum Operating Systems
    Last Post: 2012-08-07, 09:28 PM
  3. Plotting problems with Oce Windows Raster Driver.
    By FWSchreck in forum Revit - Plotting/Printing/Exporting
    Last Post: 2006-11-16, 07:51 PM
  4. PLOTTING SLOW AFTER WINDOWS XP UPGRADE
    By DEBBIS in forum AutoCAD LT - General
    Last Post: 2004-11-05, 06:25 PM
  5. Plotting Problems - view windows shifting
    By Revitor in forum Revit - Plotting/Printing/Exporting
    Last Post: 2003-09-25, 05:20 PM
