Thread: windows 10 plotting
    2016-06
    5
    Default windows 10 plotting
    I have AutoCAD civil 3d, and adobe pro, but when I go to plot a PDF, the PDF opens in internet explorer and I don't understand why. I've made adobe my default PDF viewer and disabled all of the internet explorer add-ons. My company is slowly making the switch to windows 10 and I think that it's causing this problem but I'm not sure.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: windows 10 plotting
    What version of Civil 3D are you using? Is it 32-bit or 64-bit?
    This may help: https://forums.adobe.com/thread/1086608
    Earth
    9,804
    If you are on Windows 10, it's probably hijacking your "default" PDF application.
    Are you sure it isn't Edge that is opening, not IE?
    R.K. McSwain | CAD Panacea |
    2009-11
    5,719
    In File Explorer, right click a .PDF file, select Properties menu item, on General tab to the right of 'Open with:' click the Change button, select Adobe Acrobat (or your preferred PDF application), click OK button, then click the OK button on the file properties dialog.
    If your firm is standardized on using Acrobat (or other) for PDFs, your IT Admin can also set the default PDF file association using Group Policy (GPO): http://theitbros.com/set-default-fil...-group-policy/
    Cheers
    Computer Specs:
  1. 2013: Plotting to pdf in windows 7
    By vanderloo5 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2012-10-26, 05:43 PM
  2. Windows 7 - Windows 7 Autocad 2012 Plotting Issue
    By richelleharp in forum Operating Systems
    Last Post: 2012-08-07, 09:28 PM
  3. Plotting problems with Oce Windows Raster Driver.
    By FWSchreck in forum Revit - Plotting/Printing/Exporting
    Last Post: 2006-11-16, 07:51 PM
  4. PLOTTING SLOW AFTER WINDOWS XP UPGRADE
    By DEBBIS in forum AutoCAD LT - General
    Last Post: 2004-11-05, 06:25 PM
  5. Plotting Problems - view windows shifting
    By thsmith1804 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2003-09-25, 05:20 PM
