Thread: How to load USGS DEM info into Civil 3D
    2016-04
    California
    150
    Default How to load USGS DEM info into Civil 3D
    Hey guys,
    Does anyone know how to download DEM info from the USGS site into Civil 3D so that one could see the topo info, like contours from their topo maps?
    Thanks
    TN/KY Area
    1,640
    Default Re: How to load USGS DEM info into Civil 3D
    You can create a surface from a DEM then style it to show the contours. Another way if all you want to do is see the topo is use the map3d tools Data Connect and add a raster file then select the DEM.
  1. Civil 3D 2010 Hovering point info
    By andy in forum AutoCAD Civil 3D - General
    Last Post: 2009-06-11, 02:45 PM
  2. Access Civil 3D info using Lisp
    By ccowgill in forum AutoLISP
    Last Post: 2008-06-07, 12:06 AM
  3. True View convert civil info?
    By cadman_meg in forum AutoCAD General
    Last Post: 2007-10-16, 03:15 PM
  4. Breaking info on Civil 3D 2007
    By jobcaptain in forum AutoCAD Civil 3D - General
    Last Post: 2006-04-24, 01:20 PM
  5. DWG civil info, and alignment issues
    By ron.sanpedro in forum Revit Architecture - General
    Last Post: 2006-03-21, 09:24 PM
Tags for this Thread
