Thread: Modeling Small Drainage features with Null Strucure
    2017-05
    19
    Default Modeling Small Drainage features with Null Strucure
    It seems that C3D is geared toward larger stormwater collection systems, with the smallest structure being a 24x24 rectangular. For smaller, on features such as patio or landscape drains http://www.kristar.com/index.php/con...drain-p-series would you just use a null structure, or create a custom part in part builder? Can null structure be modeled as such an intake within SSA?
    Also is there an online resource of custom structures such as above to be downloaded/shared for free?
    Thank you
    2009-11
    5,719
    Default Re: Modeling Small Drainage features with Null Strucure
    We use [Gravity] Pipe Networks for sanitary, storm, and water mains; not sure on SSA as we don't use it (we use WaterCAD + ICPR).
    That said, I use Null Structure Styles for all fittings (plan and profile), but also add customer structures and pipe sizes for common items not included.
    Not aware of a free online part catalog; most custom parts either only apply to internal standards, or those of local municipalities/manufacturers. Actually, Florida DoT has a Civil 3D State Kit that provides all of their drainage structures, now that I think of it.
    Cheers
    Computer Specs:
    2015-10
    Central New Jersey
    439
    I just made my own parts by copying the standard ones out of the box and editing the available sizes. Example, when I needed 4" drainage cleanouts I took the basic cylindrical structure and edited the available inside diameter values to include 4", 6", 8" and 12". (with thinner sidewalls too)
    The ones out of the box are basically a series of examples of what you could do.
  1. 2016: Tactics on Small Residential Drainage
    By Sterling2017 in forum Civil 3D Tips & Tricks
    Last Post: 2019-06-05, 01:32 PM
  2. AU308-4L: Compelling Features of 3D Part Modeling in AutoCAD
    By Autodesk University in forum AutoCAD
    Last Post: 2014-11-17, 05:28 AM
  3. GD115-3: Compelling Features of 3D Part Modeling in AutoCAD®
    By Autodesk University in forum General Design
    Last Post: 2013-05-06, 01:34 AM
  4. Modeling brick features
    By dzatto in forum Revit Architecture - General
    Last Post: 2010-10-05, 10:45 PM
  5. Modeling a small dam
    By denisgonzalezg189 in forum AutoCAD Civil 3D - General
    Last Post: 2009-11-20, 12:42 AM
Tags for this Thread
