Results 1 to 6 of 6
Thread: instance parameters in family will not change in revit 2018.1
    2007-06
    12
    Default instance parameters in family will not change in revit 2018.1
    I have families with instance parameters that change stuff in the project which have all other versions but in 2018.1 they will often not work. I created a video that shows what happens. https://www.screencast.com/t/XCsrlGwERKO9
    I can check the box or change the numerical value and the "apply" button will become active until I try to select it. then it grays out and the change that I made reverts to what it had been.
    Sometimes if I go to a different view or reopen the project or sync then it will work as it should.
    2007-06
    12
    Default Re: instance parameters in family will not change in revit 2018.1
    Bump
    This problem is happening with all of my families that have nested families in them. The most strange part is that I can sometimes change the values and other times not.
    2017-10
    I am having the same problem. I do not know the cause or solution but I do have a workaround. Whenever you change a parameter like this, double press "enter" QUICKLY and that will make it stick. I share in your frustrations.
    3
    Exclamation Re: instance parameters in family will not change in revit 2018.1
    Quote Originally Posted by dbrailey757595 View Post
    I am on Revit 2018.2 and having the same issue with instance parameters...it is becoming very frustrating!
    Curt
    2015-08
    Denver
    4
    Bump
    i am having the same issue with 18.2.0.51
    this is infuriating to make changes to parameters and not have them stick
    2012-10
    Cape Town, South Africa
    34
    It must be a bug. I have had the same problem in 2018 as well. I have found that some of the instance parameters "stick" after a few tries, but it should not be bugged to start of with... 18.2.0.51 as well
  1. 2015: Family Instance Parameters Problem
    By Valanova89 in forum Revit MEP - Families
    Last Post: 2016-09-06, 08:46 PM
  2. Replies: 0
    Last Post: 2012-07-04, 08:07 PM
  3. Change fixed "Type" parameters to "Instance" parameters.
    By autocad.wishlist1734 in forum Revit MEP - Wish List
    Last Post: 2011-10-10, 11:52 AM
  4. Instance Parameters in an Annotation Family
    By dlancor in forum Revit Architecture - General
    Last Post: 2007-05-30, 06:21 PM
  5. Instance Parameters in Family Formulas.
    By Scott Hopkins in forum Revit Architecture - General
    Last Post: 2003-06-14, 02:38 AM
