Thread: instance parameters in family will not change in revit 2018.1
    2007-06
    12
    Default instance parameters in family will not change in revit 2018.1
    I have families with instance parameters that change stuff in the project which have all other versions but in 2018.1 they will often not work. I created a video that shows what happens. https://www.screencast.com/t/XCsrlGwERKO9
    I can check the box or change the numerical value and the "apply" button will become active until I try to select it. then it grays out and the change that I made reverts to what it had been.
    Sometimes if I go to a different view or reopen the project or sync then it will work as it should.
    2007-06
    12
    Default Re: instance parameters in family will not change in revit 2018.1
    Bump
    This problem is happening with all of my families that have nested families in them. The most strange part is that I can sometimes change the values and other times not.
  1. 2015: Family Instance Parameters Problem
    By Valanova89 in forum Revit MEP - Families
    Last Post: 2016-09-06, 08:46 PM
  2. Replies: 0
    Last Post: 2012-07-04, 08:07 PM
  3. Change fixed "Type" parameters to "Instance" parameters.
    By acadwishlist in forum Revit MEP - Wish List
    Last Post: 2011-10-10, 11:52 AM
  4. Instance Parameters in an Annotation Family
    By dlancor in forum Revit Architecture - General
    Last Post: 2007-05-30, 06:21 PM
  5. Instance Parameters in Family Formulas.
    By Scott Hopkins in forum Revit Architecture - General
    Last Post: 2003-06-14, 02:38 AM
