Thread: Manual Point Creation
    2015-05
    West Des Moines
    179
    Default Manual Point Creation
    We have an old survey template that we're updating and due to how many issues it has we decided to start fresh. We have a Description Key Set and on import through a survey database everything works fine. If I use manual points creation and I use a description key with a specific point style it works fine as well. However, if I manually create points it does not respect all of the settings for points that do not have a specific point style (like a ground shot).
    I have set the default point style to mimic a point style called MC_Standard. I have done this by going into toolspace > settings tab > point > right click > edit feature settings and setting the default styles to MC_Standard. In the case of a non-specific point style it is supposed to create a circle and the label style (regardless of using a specific point style or not) should show the point number, elevation, and raw description. Instead it shows an X with no label.
    However, this is where it gets more fun. The point created manually still says it's using default point style and default point label style. I have been scouring toolspace and other settings to try to figure out where this setting is controlling it. Another weird thing I stumbled upon was that if you bring up the points creation pop-up box I was able to set "Disable Description Key Set" from false to true. This causes manual points to create the points the way I wanted to, but then it caused the points with specific point styles to not create properly. I don't get why disabling description key set causes it to work properly. The current description key set in my new template is something we did preserve from the old template.
    Any help is appreciated.
    2015-05
    West Des Moines
    179
    Default Re: Manual Point Creation
    Figured it out.
    Any point I created got dumped into the All Points point group which was not set to the proper point/point label settings. If I used a description key that had been assigned a specific point style and label style it superseded the All Points settings. If it didn't it acquired the All Points settings.
    Probably should have figured that one out earlier...It's not like I spent a ton of time screwing around with every other setting under the sun or anything.
    *slowly walks out of thread...*
  1. 2015: Création terrain avec fichier Point 3D DWG ....
    By cnevians@yahoo.fr in forum Revit Architecture - Général
    Last Post: 2014-10-03, 07:55 AM
  2. Grading Objects - Point Creation
    By dkelsh in forum AutoCAD Land Desktop - General
    Last Post: 2012-01-30, 04:00 PM
  3. Point Creation
    By Garland in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2011-04-20, 01:54 PM
  4. Manual AEC Dims??? Whats the point?
    By H-Angus in forum ACA General
    Last Post: 2006-02-27, 03:31 PM
  5. Replies: 2
    Last Post: 2006-01-27, 05:29 PM
