Thread: pdf underlay
    2004-06
    Slidell, Louisiana
    972
    Default pdf underlay
    I scanned a print of a proposed layout to a pdf. attached the pdf to my drawing.
    i first clipped the pdf to only show what i was interested in and aligned the pdf about two known points.
    when i zoomed in to see how it looked, the pdf had clipped the area even more so that a part of what i needed was missing.
    then i undid everything back to the full pdf. drew a reference line that is was going to use as an aligning tool.
    drew the corresponding line in the drawing. again i zoomed into the pdf and it got smaller than the reference line. when zoomed previous, the line was correct.
    zoom in and it is short.
    don't know whats happening. i've attached 2 images
    2014-08
    447
    Default Re: pdf underlay
    Did you tell it to apply scale with rotation, check make sure all your pts have the same z value
    2004-06
    Slidell, Louisiana
    972
    everything has and elevation of zero. funny this is, i saved and exited the dwg.
    opened it back up and don't have that problem anymore.....at least for now.
  1. 2012: Underlay RCP and Underlay Orientation
    By SamuelAB in forum Revit Architecture - General
    Last Post: 2012-08-08, 05:27 PM
  2. 2011: PDF underlay
    By andre.gawlik in forum AutoCAD General
    Last Post: 2010-11-19, 10:02 AM
  3. underlay
    By Bluefairy in forum Revit - Student Support
    Last Post: 2010-10-23, 08:42 PM
  4. UNDERLAY??
    By yishida in forum Revit Architecture - General
    Last Post: 2006-05-31, 02:23 AM
