Thread: Revit 2016, How to use same family devices I used in earlier project. In Autocad you just use same mep-file
    2017-08
    4
    Lightbulb Revit 2016, How to use same family devices I used in earlier project. In Autocad you just use same mep-file
    Hi dear members
    When I as an electrical engineer create a new project in Revit 2016 I have to load every single electrical device again.
    My Questions is:
    Can I use same file I have in earlier project to the new one so I can scip to load new devices again in every project?
    Like autocad, there is a mep-file you add and then you have same devices.
    Hope anyone here can solve it and thank you for your interest.
    With best regards
    2015-11
    Saint Louis, MO
    485
    Default Re: Revit 2016, How to use same family devices I used in earlier project. In Autocad you just use same mep-file
    yes, you can load your commonly used devices, all your electrical settings, view settings, etc. in a template file to start projects with.
    you can also drag your devices into a project via windows explorer, for your already started projects.
    hth,
    mike
    2017-08
    4
    Thank you Mhartmann for your fast answer.
    Not so easy for me to understand your answer, I'm not that profetional Revit user hehe
    For example in my existing project when i choose lighting device under properties toolbar I have all loaded luminairies to choose between menwhile in a New project I have to load all devices again. I will be thankful if you can explain how I can avoid to load all luminaries/devices again (avoid to repeat) and use from another project file there I allready have loaded all devices I need, if it works on Revit.
    Hope you understand my explaining.
    Thank you!
    All AUGI, all the time Duncan Lithgow's Avatar
    2006-09
    Denmark
    621
    Sounds like you'd be happy to understand more about Project Templates. http://help.autodesk.com/view/RVT/20...8-C199B1BC4207
    You can set up a project template with all the families you would typically need. But you can also import large groups of families from the same folder by selecting then via the 'Load Family' tool: http://help.autodesk.com/view/RVT/20...6-CAB6C362049A
    2017-08
    4
    Thanks all for the help, I appreciate your help! <3
  1. 2016: AutoCAD Plant 3D (2016) Report Creator Not Updating with Project
    By CASk8er in forum AutoCAD Plant 3D - General
    Last Post: 2017-06-29, 09:58 PM
  2. 2016: Revit 2016 Project Address: Did Autodesk change how it functions?
    By bdorsey.189306 in forum Revit Architecture - General
    Last Post: 2015-12-11, 07:10 PM
  3. 2016: Autocad Arch 2016 Floating File Path on screen
    By janderson664783 in forum ACA General
    Last Post: 2015-08-12, 02:11 PM
  4. 2016: Publish command is slow to open in AutoCAD 2016 & AutoCAD 2016 LT
    By leinsterlady in forum AutoCAD Plotting
    Last Post: 2015-07-14, 07:42 PM
  5. 2016: AutoCAD MEP 2016 File Path Display
    By mviall681618 in forum AutoCAD General
    Last Post: 2015-05-08, 05:38 PM
Tags for this Thread
