Thread: Set the Revit Link Display Settings to "Linked View"
    2005-12
    27
    Default Set the Revit Link Display Settings to "Linked View"
    Hello,
    I have a campus project with 200+ linked building models and I want to use the API to set the visibility of all the Revit Links to "By linked view" and select the linked view to use (see attachment below for the setting).
    I searched the API help file but I could not find any Classes or Methods related to this. Is it possible to access these settings with the API?
    Jason
    2015-12
    19
    Default Re: Set the Revit Link Display Settings to "Linked View"
    The current API as of Revit 2018.1 does not seem to provide access to this functionality. You might have to do the whole thing yourself (i.e. get the view visibility settings from the Revit link and apply it as element graphic overrides in the active view, if that is even possible for linked elements).
    2005-12
    27
    Thanks for your response, we will look for another way.
  1. 2016: when "display settings" is set on "by linked view" hiding an single elements isnt possible?
    By danezeq390391 in forum Revit Architecture - General
    Last Post: 2016-06-09, 09:40 PM
  2. Bug? Phase filter settings "By Host View"
    By dbaldacchino in forum Revit Architecture - General
    Last Post: 2013-09-12, 01:52 AM
  3. I wish Revit could "Reference Other View" from linked files
    By sfong in forum Revit Architecture - Wish List
    Last Post: 2011-10-17, 03:14 PM
  4. 2012: Perspective view of Revit linked files shows "phantom" elements
    By Andre Carvalho in forum Revit Architecture - General
    Last Post: 2011-07-09, 07:53 AM
  5. Replies: 3
    Last Post: 2007-10-23, 09:06 PM
