Results 1 to 7 of 7
Thread: PTYPE COMMAND
    2004-06
    Slidell, Louisiana
    972
    Default PTYPE COMMAND
    Is there a problem in civil3D 2017 with the ptype command?
    i get an a message saying "Command: PTYPE
    Unknown command "PTYPE". Press F1 for help but yet it is listed in the help.
    9,804
    Default Re: PTYPE COMMAND
    Type prefixing the command with a period (i.e.: Command: .PTYPE)
    If the command has been undefined, this will bypass that.
    BTW: It works just fine here in C3D 2017.
    2015-05
    West Des Moines
    306
    As to why it may not work, are you running any lisp routines that may screw the command up?
    I created a command function called "off" and it turns out one of my co-workers used off for offset (instead of O...) so it messed with him.
    2004-06
    Slidell, Louisiana
    972
    thanks for the info. i will try the suggestions. i may try exiting autocad completely and restart....not at my computer today. will let you know the results.
    Tallahassee, FL USA
    3,667
    Quote Originally Posted by CCarleton View Post
    By default entering OF or OFF should start the OFFSET command in either AutoCAD or Civil 3D with AutoComplete turned on. O is the default Command Aliases for the OFFSET command.
    To many AutoCAD, Map, and Civil commands to remember them all. Best to test on the command line before defining something as a name for a function. Had a few that stopped working for me years ago when they added AutoComplete. Had to rename my functions.
    Civil Engineering Moderator MHultgren's Avatar
    Indy West (Not West Indies)
    1,446
    You can always print out the acad.pgp file and highlight the commands you use the most to learn (or change) the shortcut key for those commands. The Express tools Editor still works well in 2018
    2004-06
    Slidell, Louisiana
    972
    A simple close and exit and restart Acad did the trick. I don't know why this happened and i don't have any shortcuts, lisps or command alias shortcuts other than what is OOTB.
  1. Replies: 6
    Last Post: 2018-07-20, 07:28 PM
  2. automatic multiple command when creating a fillet like copy command
    Last Post: 2012-01-18, 06:25 PM
  3. Replies: 6
    Last Post: 2007-04-23, 01:40 AM
  4. Replies: 4
    Last Post: 2006-05-09, 08:57 PM
  5. Replies: 8
    Last Post: 2005-06-30, 02:32 PM
