Hi All!
The vault projects properties in the project editor are not editable. Is there a way to add a r/w library to the vault project I'm currently using?
Background:
I have been using inventor with vault basic since 2015 release. I have a single vault project I use for everything. I have upgraded to 2016. I have been working on a project that requires a MT/WT T from the Frame Generator and this part worked when I started this project in the 2015 release. Now in 2016 there is a known bug for this frame generator part. The work around would be to publish the T part I need to the content center. Works fine in a non vaulted project but because I don't have a r/w library in vault it fails.
The first fix would to have Autodesk release a fix for this frame generator part but till then.... I'm Stuck.
I'm a noob when comes to vault and vault has been a mix of pluses and minuses since I started using it, but we are a multi user environment so I feel we need to use it.
The vault projects properties in the project editor are not editable. So I can't add a Library directly. Is there a way to add a r/w library to the vault project I'm currently using? Or is there a different solution?
FIY: In my Vault Server Console I have R/W Libraries but I don't see them in the Vault Basic Client or when I create a new vault project in the project editor.
Thanks for your help.
John
