Thread: ATTRIBUTES IN DYNAMIC BLOCKS GET #### AFTER REOPENING OF DRAWING
    2017-08
    Default ATTRIBUTES IN DYNAMIC BLOCKS GET #### AFTER REOPENING OF DRAWING
    I am trying to make a dynamic (length and width) column block with attributes for width, length and column no. It is working fine. But when I open the drawing again, the length and width is showing #####.
    2015-10
    Central New Jersey
    439
    Default Re: ATTRIBUTES IN DYNAMIC BLOCKS GET #### AFTER REOPENING OF DRAWING
    Could you post the block so we can see whats going on?
    2008-12
    New Jersey
    472
    Not sure if the ATTSYNC command will fix the attributes or not but you could give it a try and see if it will resync them.
    2017-11
    Hi,
    While editing attribute in default tab go to insert field in that Block place,Select block reference property as distance1 ( Linear Parameter) and then Click ok to continue.After closing the Block delete the current block on the window,but dont purge.Insert that block again.
  1. Replies: 0
    Last Post: 2011-11-15, 01:35 PM
  2. Attributes in Dynamic Blocks
    By d.leigh in forum Dynamic Blocks - Technical
    Last Post: 2008-12-17, 03:36 PM
  3. Attributes in Dynamic Blocks
    By jodi_sherrell in forum Dynamic Blocks - Technical
    Last Post: 2008-09-30, 10:29 PM
  4. Attributes in dynamic blocks
    By Hooch in forum Dynamic Blocks - Technical
    Last Post: 2008-04-15, 02:36 PM
Tags for this Thread
