Results 1 to 7 of 7
Thread: Featureline Quick Relative Elevation Editor
    2004-08
    Iron Station, NC
    3,198
    Default Featureline Quick Relative Elevation Editor
    I cant find it, and with all the tools that are available, I cant believe that this one doesnt exist. I think almost all the tools that are available in the elevation editor table, are also available to edit points outside of the table, graphically on screen, except the one I need.
    I'm looking to adjust a pi's elevation by a relative amount. I'm running curb feature lines, and I've got my back of curb, where I need to dub it down for sidewalk ramp access. I cannot find a fast way to just say, drop this point or these 5 points 0.42 feet. The elevation editor can do it, but I spend way too much time guessing what my start and end stations are. I dont want to lower the entire feature line, just small portions of it.
    Any suggestions would be appreciated,
    Thanks,
    2015-10
    Central New Jersey
    439
    Default Re: Featureline Quick Relative Elevation Editor
    Try this.
    Draw a new feature line, within the same site, of the same style, on top of the area range you want to lower. The new feature line will pick up the elevation of the current line and they will react to each other. Now use the lowering tool to lower this new feature line and the original line will react with it.
    5,719
    I usually just break the Feature Line at start and end of the segment I need to lower, perhaps add any critical vertices to the adjacent segments before and after the segment to be lowered (i.e., for curb transitions, etc.), then select the desired segment, right click and select Raise/Lower menu item. Done.
    This also helps to prevent unintentional SETFEATUREGRADE command calls from changing this segment by not being able to pass through the lowered segment (if that makes sense).
    Cheers
    2008-12
    New Jersey
    472
    I use the Quick Elevation Edit Routine. Select the feature line then snap to the point you want to edit and adjust the elevation.
    2004-08
    Iron Station, NC
    3,198
    Quote Originally Posted by Iceberg View Post
    that works, if I know the elevation I want. In this case, I want to adjust the elevation relative to the current elevation the point already has. Unless there is some option that I dont seem to be able to find.
    Cairo - no, not Illinois
    5,069
    presuming the current elevation is 17.363, and you want to lower it a half-foot, key in (- 17.363 0.5).
    2015-10
    Central New Jersey
    439
    I draw a new feature line over the section I want to lower then lower that new feature line by 0.5. The new feature line will react with the old one and lower its elevations in that area the same amount.
    The new feature line could be given a different style with a higher rank in the site properties and take control of those elevation points.
  1. Pipe Network QUICK! Elevation/Invert editor
    Last Post: 2014-06-18, 10:49 PM
  2. 2013: Elevation Editor Jumps to Bottom of List after Editing Elevation Value
    By aspencer.226869 in forum AutoCAD Civil 3D - General
    Last Post: 2014-03-21, 07:01 PM
  3. Replies: 3
    Last Post: 2013-12-20, 03:52 PM
  4. Placing bar joists relative to top of steel elevation
    By david_spehar in forum Revit Architecture - General
    Last Post: 2008-03-12, 08:09 PM
  5. Relative vs. Actual elevation
    Last Post: 2005-08-05, 05:33 PM
