I am looking for the lisp routine (or some other method) to quickly display block look up parameter value in a multileader which is attached to the block. I am trying to find the quick method to visually tag my blocks with the look up values. normally it can be done by creating a field in the multileader and link the field to the block look up parameter. I am hoping that somebody can optimise this process and the same result can be achieved faster:
1. Run the command
2. Select arrow position for the multileader
3. Select the block look up value will be extracted from
4. Select a location to place the multileader
