Hey all,
I thought I was all over the dramas with upgrading from Revit 2016, infact we skipped 2017 to alleviate some of the issues.
Now running Revit 2018.1.
I was thinking about working around the issues of text getting larger by making a smaller version of each font size, so 2.5mm text would go down to 2.48mm(ish) and look the same. That's when I noticed some really strange rounding behavior that didn't occur in Revit 2016.
At first it seemed the "Text Size" parameter could only manage rounding to 1 decimal place. So 2.40 looked the same as 2.45, then at 2.46 it would jump up to a size of 2.50 (confirmed by changing the size to 2.50 and seeing it not change again)
I thought this was a dumb bug but at least consistent, then I went small, so 1.10 looks the same as 1.19 and only changes at 1.20, then I went big, and strangely 6.9 looks the same as 7.0 and only changes size at 6.8!
The font I'm using is Arial Narrow, I guess its the same across the board. I also guess this has something to do with metric feet and some weird 1/32nd type text sizes!
Autodesk please sort it out asap.
