Thread: Dynamic Block - Rotate and Stretch line extending from tag
    2017-09
    Default Dynamic Block - Rotate and Stretch line extending from tag
    I have a device tag with a line that I need to be able to stretch and rotate. the line should rotate around the arc of the circle in which if the line was extended, it would intersect the center point. I'd like to be able to stretch the line to my device without it leaving the circle.
    See attached.
    Any advice?
    2015-10
    23
    Default Re: Dynamic Block - Rotate and Stretch line extending from tag
    If you've created your rotate, then you don't need the circle...delete it, or move it to the defpoint layer
    2017-09
    Quote Originally Posted by cadman1957 View Post
    The circle is needed, it's part of the tag.
    2015-10
    Central New Jersey
    439
    I suggest abandoning the dynamics of the line rotate/stretch and instead use the block with just the circle and attributes in a multileader style. The functions of the leader in a multileader will take care of the line stretch and rotate. You also get more features this way, multiple leaders, move the leader or the block/text, symbols at the end, add more vertex points to the leader, etc.
    See attached file.
    2017-09
    This is exactly what I'm looking for. Thank you!
  1. Dynamic Block - Rotate+Stretch+Scale?
    By pargana175 in forum AutoCAD General
    Last Post: 2009-11-04, 04:36 PM
  2. Dynamic stretch but not rotate
    By h.jobe in forum Dynamic Blocks - Technical
    Last Post: 2009-01-05, 09:18 PM
  3. Trying to Stretch a hatch in a Dynamic Block with the Stretch parameter
    By hnewman in forum Dynamic Blocks - Technical
    Last Post: 2007-11-05, 09:34 PM
  4. Stretch and Rotate Dynamic Line Block.
    By d.vaneygen in forum Dynamic Blocks - Technical
    Last Post: 2006-04-10, 03:50 PM
  5. Dynamic Blocks - Rotate & Stretch
    By Jen-AWI in forum Dynamic Blocks - Technical
    Last Post: 2006-04-03, 08:31 PM
