Freeze Individual Layers Located on Object Layers
Summary: The ability to freeze layers associated with Civil3D entities, (label styles, feature lines, etc). without freezing the object layer.
Description: The ability to freeze layers associated with Civil3D entities, (label styles, feature lines, etc). without freezing the object layer.
Typically what happens is you go to an entity that is stored on an object layer, however the properties of the layer is being controlled by the physical layer assign to that object. Having the ability to be able to freeze those physical layers without freezing the entire object layer (might be several items placed on one object layer) would make it easier to manipulate drawings.
Basically its the same freeze command that works for CAD entities used to freeze layers of objects placed on object layers.
Product and Feature: AutoCAD Civil 3D - Other
Submitted By: Iceberg on 09/13/2017
Re: Freeze Individual Layers Located on Object Layers
You can do this now, with an add-on.
http://www.quuxsoft.com/SincpacC3D_H...ayerFreeze.htm
Or you can wait forever for it to not be done
- You may not post replies
- You may not edit your posts
Forum Rules
