Hello,
I wrote a macro for automatically userdefined hole in a sketch. In this macro I set the tolerance for diameter and depth.
The macro works fine for that, but if I use "Show Dimension" the tolerance is wrong. I checked that the macro sets the right parameters.
Only if I manually open the "Dimension properties...", open something (e.g. dropdownlist) and close the dialog, the correct tolerance will be shown.
Has anybody an idea or solution to fix this problem.
