Contour polyline labeling
Summary: Being able to label contour polylines at an elevation without being a surface
Description: Being able to label contour polylines at an elevation without being a surface. Were able to label contour lines in Land Desktop. This helps when labeling contouring from GIS or county data.
Product and Feature: AutoCAD Civil 3D - Surface Modeling
Submitted By: Crogers25 on 09/22/2017
Re: Contour polyline labeling
This can be done.
First, make sure your polylines are light weight polylines. (use ConvertPoly if needed) Give each polyline the appropriate elevation (z value). Then make two general label styles, one for Lines and one for curves. Have the label styles label the beginning Z value of the line/curve. Use these labels to label the line/curve of the polyline contours. Note that the label will switch between the line style and curve style depending on where its placed along the line, and will update if you move then later on. The labels can have frames and background masks as desired.
Thanks, that's a good tip!
This wish has been reported as granted and already in the software.
- You may not post replies
- You may not edit your posts
Forum Rules
