Thread: "scalelistedit" does nothing
    2016-04
    California
    150
    Default "scalelistedit" does nothing
    Why does the SCALELISTEDIT command do nothing at all? I see no dialog box or anything when the command is executed. It just goes right back to the normal command line. It seems to have no effect at all.
    Thanks in advance.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Earth
    9,805
    Default Re: "scalelistedit" does nothing
    Tom's suggestions cover the issue if the issue is that the dialog is off the screen.
    But you say that nothing at all happens. If the dialog was off the screen, the command line would not simply return to normal. It would not accept any input until you press ESC to close the dialog.
    What happens if you run the same command, but prefix it with a hyphen first to execute the command line version (ex: Command: -SCALELISTEDIT ) and then reset the scales? Does the dialog based version of this command work after that?
    R.K. McSwain | CAD Panacea |
    2016-04
    California
    150
    Update,
    I figured it out. It was in fact a hidden dialog box. It is important to type in M instead of clicking "move" in the fix method.
    Thanks to all responders.
  1. Replies: 2
    Last Post: 2016-12-22, 01:02 PM
  2. 2013: Having trouble with the "scalelistedit command", no dialogue box appears.
    By mwellman303122 in forum AutoCAD General
    Last Post: 2012-09-14, 07:44 PM
  3. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  4. ENTIDADES EN ALIGNMENT COMO "FIXED", "FLOTING" y "FREE"
    By cadia in forum AutoCAD Civil 3D - General
    Last Post: 2009-02-01, 04:21 AM
  5. Replies: 1
    Last Post: 2006-06-13, 06:36 PM
Tags for this Thread
