I have these 2 autolisp
(defun c:18BK (/ pt rad)
(if (and (setq pt (getpoint "\nPoint: "))
(setq rad "12.0"))
(CirBrk pt rad))
(princ)
and this one:
(DEFUN c:ivfrt (/ sc clay)
(setvar "cmdecho" 0)
(COMMAND "INSERT"
"*ivfrt.dwg"
"S"
(SETQ sc (GETVAR "dimscale"))
(GETPOINT) pause)
pause
) ;_ end of command
into a single Autolisp call "ivfrt"
but I can make them work together 18bk first then ivfrt next in the same autolisp
the idea is once I type "ivfrt" I select the line to break as soon as I finish this command the insert block command is next.
Please any body can help me in this one
Thank you very much
