Pouring Floor Generation
Summary: Think of how floor creation would be if you could pour it into your model!!
Description: It would be really fast and helpful if you were able to basically pour in a floor into your model. With various walls and doors and rooms and hallways, it would be great to select the desired floor level then pick a spot withing one of the areas. The floor would then basically fill the rooms and continue through doorways and into the next room. When it comes to an opening or doorway without a room on the other side of the wall it would finish the floor at that opening on the outside edge of the opening.
Having to select walls and then trace the doorways or both sides of a wall is time consuming and a complete waste of valuable time. Doors can have a recessed sill below the floor level to allow the floor to continue through the opening and into the next room. If the room is not placed then the floor would not continue.
Product and Feature: Revit Architecture - Floors
Submitted By: greg.138302 on 09/26/2017
Re: Pouring Floor Generation
Sounds like a good concept. Something like the Automatic Ceiling Tool (which works about 2% of the time), but fixed so it actually does work!
- You may not post replies
- You may not edit your posts
Forum Rules
