Thread: Tin Lines of Mid Ordinate
    2009-11
    Raleigh, NC
    944
    Default Tin Lines of Mid Ordinate
    I have attached a image. The grey TIN lines are following the peach colored Feature line nicely with the smaller mid-ordinate value.
    Why the void of TIN lines allowing better contour formation with the TIN vertice at the bottom center (of the image)
    2008-12
    New Jersey
    472
    Default Re: Tin Lines of Mid Ordinate
    I think if you flip one of the TIN lines it will fix the problem. Basically the TIN is being pulled that way based on the point information. If you have a few points in the middle there that would help define the area so that the TIN lines do not have to calculate from a point that is far away.
  1. 2016: Mid Ordinate
    By tim_newsome in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2017-10-02, 02:07 PM
  2. Help with ordinate deimensioning?
    By snorcisa in forum AutoCAD General
    Last Post: 2010-02-23, 05:10 PM
  3. Multiple Points on Extension Lines of Ordinate Dimensions
    Last Post: 2008-10-11, 09:07 PM
  4. Z co-ordinate
    By nigel.chesworth in forum AutoLISP
    Last Post: 2005-04-04, 10:11 PM
  5. ordinate dimensions *
    By jpalme in forum AutoCAD Wish List
    Last Post: 2004-06-04, 05:15 AM
