Results 1 to 1 of 1
Thread: Dimensions with MText
    2013-06
    72
    Default Dimensions with MText
    I have had this problem before, and I just fixed them 1 by 1; this time, I want to do it programmatically if possible.
    I have a drawing with dimensions whose text is MText. The drawings were originally English units, so I scaled them up to metric; all dimensions were obviously scaled wrong. Once I adjust the dimension styles, everything looks perfect, except the MText is still .1575 instead of 4.0 (which is the "Text Height" assigned to the dimension).
    I don't seem to be able to find a way to adjust the MText height, and a dump of the properties of the dimension have nothing that corresponds to that .1575 number.
    Any help would be appreciated.
    Edit: Turns out I'm an idiot; the text height was forced inside the style definition. Please disregard.
  1. MTEXT in Dimensions; Change to BYLAYER
    By ettore_c in forum AutoLISP
    Last Post: 2016-08-09, 07:32 PM
  2. Background Mask in Mtext / Dimensions LT '07
    By flansburg in forum AutoCAD LT - General
    Last Post: 2006-09-05, 06:14 PM
  3. Text/Mtext/Dimensions controlled per viewport
    Last Post: 2006-02-22, 05:36 PM
  4. Mtext Line spacing In Dimensions
    By ccowgill in forum AutoCAD General
    Last Post: 2005-09-30, 10:44 PM
