I have my electrical model set up and now the arch wants me to create the alternates. I've set the design options up and can add items but hos can I activate the archs model so I can delete and add walls. is this even possible
Thanks in advance.
Thanks in advance.
you can set visibility of the linked arch file, custom, and design options will be a tab, and turn on or off their design options in your views
if that's what you're trying to do
hth,
mike
What I would like to do is while in my mep model and in the design options alternate plan delete a wall from the arch model and add a new wall that is specifically for the alaternate
No.
It should never be your intention to delete anything from another consultants model....EVER.
You can add the wall where you believe it needs to be, then have the Architect model a wall in that place, then delete yours.
The architect will need to add that wall to the design option you need to see it in.
