Thread: Sizing CFM to determine Property Table Value
    2017-05
    4
    Question Sizing CFM to determine Property Table Value
    Hi guys,
    this Is probably the First time Asking a question in the Forums (Hopefully I wont be asking too much) Im creating a Lisp that determines the size of a given cfm value tied to a block attribute. However I'm getting a "malformed list on input" error, and I'm not sure where it's coming from. any advice would be much appreciated. I attached a .dwg of the block I'm using to manipulate.
    (defun c:Auto_size()
    (setq ss (ssget "x" '((0 . "insert")(2 . "10 x 8 Register Sets"))))
    (if ss
    	(Progn
    		(setq ss (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
    		(mapcar '(lambda (ent)
    		(setq cfm (atoi (CFM_val_lst ent "cfm")))
    				(if
    	    				(and
    						(>= cfm 51)
    						(<= cfm 0)
    	   				 );and
    					(Reprop "sort" "01")
    				);if
    				(if
    	    				(and
    						(>= cfm 76)
    						(<= cfm 52)
    	   				 );and
    					(Reprop "sort" "02")
    				);if
    				(if
    	    				(and
    						(>= cfm 121)
    						(<= cfm 77)
    	   				 );and
    					(Reprop "sort" "03")
    				);if
    				(if
    	    				(and
    						(>= cfm 176)
    						(<= cfm 122)
    	   				 );and
    					(Reprop "sort" "04")
    				);if
    				(if
    	    				(and
    						(>= cfm 177)
    	   				 );and
    					(Reprop "sort" "05")
    				);if
    		)ss)
    All AUGI, all the time Tharwat's Avatar
    2010-06
    785
    Default Re: Sizing CFM to determine Property Table Value
    Quote Originally Posted by pabloz10750282 View Post
    Hi,
    Such an error indicates that you have one or more brackets ( parenthesis ) are missing.
    2017-05
    4
    Hey!
    I've seen your previous forums, and learned so much from you and Leemac! Thank you for responding to my first post.
    Anyways, I've been Having a hard time figuring out which set of parenthesis is missing. could it be my IF statements?
    2010-06
    785
    Hey!
    Thank you so much. Its my pleasure.
    Try to use the Vlide that is available within AutoCAD and that should help you a lot.
    AutoCAD -> Tools -> AutoLISP -> Visual LISP Editor.
    Just ask if you need more help with your codes.
    2017-05
    4
    Arrow Re: Sizing CFM to determine Property Table Value
    That is a Very Powerful tool! Oh wow! That definitely makes my coding a little easier!
    Now That The code is working without errors, It seems to not pick up on my attributes. However, It has no trouble going through my "Reprop" Module:
    (defun c:Auto_size ()
      (setq ss (ssget "x" '((0 . "insert") (2 . "10 x 8 Register Sets"))))
      (if ss
        (Progn
    		 (if
    		   (and
    		     (>= cfm 51)
    		     (<= cfm 0)
    		   )			;and
    		 )			;if
    		 (if
    		   (and
    		     (>= cfm 76)
    		     (<= cfm 52)
    		   )			;and
    		 )			;if
    		 (if
    		   (and
    		     (>= cfm 121)
    		     (<= cfm 77)
    		   )			;and
    		 )			;if
    		 (if
    		   (and
    		     (>= cfm 176)
    		     (<= cfm 122)
    		   )			;and
    		 )			;if
    		 (if
    		   (and
    		     (>= cfm 177)
    		   )			;and
    		 )			;if
    	      ss
      (defun CFM_val_lst (blk tag)
        (setq tag (strcase tag))
        (vl-some '(lambda (att)
    		(if (= tag (strcase (vla-get-tagstring att)))
    		  (vla-get-textstring att)
    	     (vlax-invoke blk 'getattributes)
      (defun reprop	(blk lst / itm)
        (setq
          lst (mapcar '(lambda (x) (cons (strcase (car x)) (cdr x))) lst)
        (foreach x (vlax-invoke blk 'getdynamicblockproperties)
          (if (setq itm (assoc (strcase (vla-get-propertyname x)) lst))
    	(vla-put-value
    	  x
    	  (vlax-make-variant
    	    (cdr itm)
    	    (vlax-variant-type (vla-get-value x))
    2017-05
    4
    after debugging my program, I finally got rid of the "too few arguments statment" foreach was messing me up so i reformatted my loop statement.
    Now that it runs, I noticed the program only returns "-1" Is there anything I missed in my loop statement?any advice would be most helpful.
    (defun c:AS3 (/ ent val cfm)
      ;; Define function, declare local variables
      (if ;; If the following expression returns a non-nil value
          (setq ent	;; Assign the value returned by the following expression to the symbol 'sel'
    		(ssget ;; Prompt the user to make a selection and return the selection set if successful
    			((0 . "INSERT"))
    		       ;; Filter the selection to block references only (INSERTs)
    		;; end ssget
        ;; end setq
        (Setq I -1)
        (While (setq ent (ssname val (setq I (1+ I))))
          (setq val (LM:Tag_Val (vlax-ename->vla-object ent) "CFM"))
          (Cond
    					;If
    	((>= val 51)
    	 (<= val 0)
    	 (LM:reprop "sort" "01" ent)
    					;Else
    	((>= val 76)
    	 (<= val 52)
    	 (LM:reprop "sort" "02" ent)
    					;Else
    	((>= val 121)
    	 (<= val 77)
    	 (LM:reprop "sort" "03" ent)
    	((>= val 176)
    	 (<= val 122)
    	 (LM:reprop "sort" "04" ent)
    	((>= val 177)
    	 (LM:reprop "sort" "05" ent)
          )					;End cond
          (defun LM:reprop (blk lst / itm)
    	(setq
    		      lst
    	    (vla-put-value
    	      x
    	      (vlax-make-variant
    		(cdr itm)
          (defun LM:Tag_Val	(blk tag)
    		      (atoi (vla-get-TextString att))
  1. Help Setting Table Column Style Property
    By svajk394200 in forum Bridging the Gap: LISP -> .NET -> LISP
    Last Post: 2017-04-23, 06:55 AM
  2. PROPERTY SETS into a Table
    By rodrigo.239853 in forum ACA General
    Last Post: 2010-03-29, 01:35 PM
  3. Create Property Line By Table - Revise Arc Entry
    By kspear in forum Revit Architecture - Wish List
    Last Post: 2007-09-06, 06:01 PM
  4. Formula property in schedule table.
    By arcadia_x27 in forum ACA General
    Last Post: 2007-08-20, 03:25 AM
  5. Property Lines by table won't rotate
    By k.armstrong in forum Revit Architecture - General
    Last Post: 2005-10-14, 04:05 AM
