Thread: Importing Named Dimension Style from Drawing "A" into Drawing "B" with Same Named Dim Style
    2005-04
    112
    Unhappy Importing Named Dimension Style from Drawing "A" into Drawing "B" with Same Named Dim Style
    I would like to use ADC or Express Tools Dimstyle Export-Import to update a named Dimension style in a particular drawing from another drawing that uses the same Dim Style. But after experimenting with ADC & Express Tools Dimstyle Export-Import, the settings for the Dimstyle persist in the drawing I want to update the Dim Style of. Any suggestions?
    Cairo - no, not Illinois
    5,069
    Default Re: Importing Named Dimension Style from Drawing "A" into Drawing "B" with Same Named Dim Style
    Rename the dimstyle in the old drawing, import the replacement style, select all old dimensions, change the style in Properties, and rock on.
    2015-10
    Central New Jersey
    439
    DIMEX --> Export dimension style
    DIMIM --> Import dimension style, with option to overwrite existing style
    2005-06
    in the upper right corner
    3,507
    Quote Originally Posted by MMccall View Post
    holy c@rp!! that was a nice tip, never heard of that before.
    cadtag's suggestion was the way I would have gone too.
    2005-04
    112
    I tried that option before I posted. The same-named Dim style's settings still persist.
  1. Replies: 7
    Last Post: 2007-09-26, 08:53 PM
  2. Replies: 8
    Last Post: 2007-04-04, 12:39 PM
  3. Dimension - "fixed length extension style" not working
    By hausmeister25 in forum AutoCAD General
    Last Post: 2006-07-13, 01:44 PM
  4. Dimension Style, variable "Round Off" (Primary Units)?
    By stephan.villeneuve in forum AutoCAD General
    Last Post: 2006-07-07, 07:34 PM
  5. Change DWG Plot Style from "stb" Style to "ctb" Color
    By andrewp in forum AutoCAD General
    Last Post: 2005-03-28, 05:31 PM
