New to CAD 2013 - Started drawing in Model with limits set at 420,297 - Area no more than 4m x 3m but when select Zoom - Enter - Extend I end up with model area 115204, -3183975,0
And no sign of my work
How can I correct this please
likely there's some tiny bit out in the ozone somewhere, maybe a blank text string or zero length line, of a block with no entities associated with the definition.
Try purging, and ensure that the "unnamed objects" item is checked.
If that doesn't resolve it, turn QTEXT on, regen, and see if you can select anything out there.
also, please verify what LIMMIN returns.
Tried purging but for some reason it would not let me select the "unnamed object" so I tried QTEXT then Regen but nothing happened - No doubt you are correct, a wee bit of something sitting in the outer region and so small when I Zoom - Extent I just cannot see it.
Going to see if I can copy my work on to a new Template - not sure how but give it a try
You might want to make sure your object isn't on a frozen or locked layer.
If you can't get rid of the extra whatever. then selecting the objects you what to keep wblock them out into a new dwg
Hi
Gone with the WBLOCK and put my work in a new drawing - Thank you for your help
- - - Updated - - -
Hi Ted
Tried CTRL+A but nothing came up outwith my work so went with WBLOCK and put it in a new drawing - Thanks for your help
