Thread: fonts arent fitting in box (or visa versa?)
    2010-05
    94
    Default fonts arent fitting in box (or visa versa?)
    i just did a fresh new install and im having font issues or dialogue box issues, they are fitting well together. see 2 image files attached. i tried toggling the autocad "options" display" "use large buttons for toolbars" and also the windows 10 settings, display slider.. change text size apps, etc.. that didnt work either.
    any suggestions what this could be?
    thanks for the help!
    2010-05
    94
    Default Re: fonts arent fitting in box (or visa versa?)
    figured it out.. found this method
    Disable DPI scaling for AutoCAD:
    - Right-click the AutoCAD shortcut or the acad.exe program file and choose "Properties"
    - On the "Compatibility" tab, select "Disable display scaling on high DPI"
    - Click OK
  1. Projects that use Visa Lighting Files
    By gjackson in forum Revit - R & D Lounge
    Last Post: 2009-02-25, 02:28 AM
  2. Visa Lighting Families
    By dpasa in forum Revit Architecture - Families
    Last Post: 2008-09-23, 12:52 PM
  3. Visa Lighting has Revit Files
    By mstuver876126 in forum Revit MEP - General
    Last Post: 2007-11-21, 06:57 PM
  4. Some families editable in v8, some arent?
    By Kroke in forum Revit Architecture - Families
    Last Post: 2005-08-25, 12:01 AM
