Thread: Data Extraction of Specific Block Attributes to Existing Excel Sheet
    2017-10
    15
    Question Data Extraction of Specific Block Attributes to Existing Excel Sheet
    Hello,
    I have an AutoCAD Drawing with different Blocks. These blocks have some of the attributes names in common (Height, Length & Width).
    Can I extract the attribute data from selected area in drawing to an existing excel sheet with standard template such that the block name comes under column named "Block Name", Value of Height Attribute comes under column "Height" and so on?
    Here are the list of things I wanted to do in attached drg
    1. Extract data from some blocks (Block Names are: SA GRILLE, SA Slot Diffuser, SA Sq Diffuser, Shoe Piece, Straight Duct, Transition, Elbow) from selected area on drg.
    2. Extract the values of Attributes named WIDTH, HEIGHT, WIDTH2, HEIGHT1 & LENGTH
    3. The Data should be extracted to an existing excel sheet as attached.
    4. The data extracted should come under respective column label.
    Is this feasible using VBA?
    Here are some links which are helpful but I couldn't get desired results using those.
    http://www.lee-mac.com/macatt.html
    http://www.cadtutor.net/forum/showth...ing-excel-file
    Dynamic Blocks Data.xlsx
    Dynamic Blocks.dwg
    2003-07
    560
    Default Re: Data Extraction of Specific Block Attributes to Existing Excel Sheet
    1 look at other post at Cadtutor
    2 using VBA you can simply get at the attributes
    3rd there is VBA to excel examples out there just Google
    Set SS = ThisDrawing.SelectionSets.Add("pit1sel")
    SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal
    For Cntr = 0 To SS.Count - 1
    If SS.Item(Cntr).Name = BLOCK_NAME Then
       attribs = SS.Item(Cntr).GetAttributes
         If attribs(0).TextString = pitname Then
    2013-02
    13
    Quote Originally Posted by sbmunde View Post
    Hello,
    Dynamic Blocks.dwg
    Check out the Excel workbook in this post - http://forums.augi.com/showthread.ph...xtraction-Tool
    Should be an excellent starting point for your project.
  1. 2013: Batch extraction of title block attributes to excel
    By robechandler167079 in forum AutoCAD General
    Last Post: 2015-04-28, 07:29 PM
  2. 2014: Data Extraction Table not Updating to the Excel Sheet
    By JHARSH in forum ACA General
    Last Post: 2014-08-05, 08:55 PM
  3. Replies: 2
    Last Post: 2012-06-06, 12:28 PM
  4. dynamic block with attributes extraction to excel
    By parkerfeldman in forum AutoLISP
    Last Post: 2009-01-27, 09:14 PM
