Multiple Schedule Field Selection
Summary: I want to be able to effect a change to multiple value fields in a schedule, with one change.
Description: I want to be able to select multiple value fields (of a single column) in a schedule, and change all of the values at once. Those selected values may or may not be the same to start.
Currently, there are times when you can effect a multiple value edit (as I'm requesting here), if you un-check the "itemize" box. But... you must have your schedule filtered correctly and there are many times when even then, this process just doesn't work.
Product and Feature: Revit Structure - Other
Submitted By: DToolman on 10/25/2017
- You may not post replies
- You may not edit your posts
Forum Rules
