CCarleton
Oh, not a bad idea at all. I'm not sure why I didn't think of working with the description format like I did with tree formatting. I guess I tunnel visioned point label styles, setting parameter 0 up to properly to populate the field (They will shoot a manhole as SM600 and up for tracking them), using a typical elevation field, and then staring at the rest of my options in the label realizing I couldn't do much with it.
However, is there a way to have it do any calcing in the format? We do the math so your north elevation should say 13.52 feet instead since 23.64-10.12 = 13.52. I'll try my hand at some googling to see what I can find.
Regardless, my other issue how to get around manholes with varying numbers of pipe. So, in theory, this works well if every manhole had the same number of pipes, but that obviously doesn't happen, let alone pipe direction, size, and in or out.
Using your label this is how our labels would look (Assuming 8" PVC)
SM610
RIM: 23.64
8" PVC FL N IN: 13.52
8" PVC FL E OUT: 10.40
8" PVC FL S IN: 10.42
With that much information in the label it feels tricky getting all of it to populate properly in an automatic fashion.
Thanks!
