Revit zoom factor (zoom speed)
Summary: Revit should have setting for changing mouse wheel zoom factor, because the default zooming is so slow.
Description: I wish there is a setting for changing mouse wheel zoom factor in Revit. To zoom using "Ctrl + mouse" and "Navigation Wheel" menu isin't an option for fluid workflow. Windows 10 mouse wheel scroll settings doesn't change the scroll factor in Revit. Logitech Setpoint also don't have any effect. Revit's default zoom is so slow. When I have big plans, then there is so much zooming to get to the detail I want to work with. If I could change zooming factor in Revit, then it will be much less scrolling with my wheel. Maybe there have to be accelerated zoom also, so that if I scroll mousewheel slowly, then the zooming increment is small, but if scroll quickly, then it jumps from the sky to the little object on the ground.
Product and Feature: Revit Architecture - Other
Submitted By: andrease.kirjad595670 on 11/01/2017
- You may not post replies
- You may not edit your posts
Forum Rules
