Thread: hexagon shape around numbers in Mtext
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Default hexagon shape around numbers in Mtext
    I have a couple of engineers in another of our offices who have put a hexagon shape around numbers to indicate what part of the drawing notes apply. They also want to put a hexagon around each of the numbers in the note, within the text of the Mtext. Is this doable, quickly and easily within the text? TIA
    Earth
    9,805
    Default Re: hexagon shape around numbers in Mtext
    One way.....
    Create a table (even if you don't need it), and insert a BLOCK into one of the cells.
    Choose the built-in block named "_TagHexagon".
    From this point forward, this block will be available to you in the drawing.
    R.K. McSwain | CAD Panacea |
    2015-10
    Central New Jersey
    439
    Just a thought: Multileaders can use a block as part of the style, a block with attributes. There is a command MleaderCollect that will arrange a selection of these mleaders and stack them vertically (or horizontally) with on leader. My thought was to make an Mleader style with hexagon, a number attribute in the middle of the hexagon and a second attribute to the side for a note.
  1. 2015: Mtext Bulleted Numbers (period removal)
    By CAHONDACT70 in forum AutoCAD Annotation
    Last Post: 2017-08-01, 05:55 PM
  2. Display Roman numerical numbers in DText and MText
    By rmk in forum AutoCAD General
    Last Post: 2012-05-10, 05:34 AM
  3. Mtext Symbols acting as Bullets or Numbers
    By SRBalliet in forum AutoCAD General
    Last Post: 2008-03-20, 01:38 PM
  4. Lisp to extract and add numbers from text/mtext string
    By cblendermann.91943 in forum AutoLISP
    Last Post: 2005-08-18, 03:25 PM
Tags for this Thread
