Thread: Batting
    2014-03
    5
    Default Batting
    When I use the Layer BATTING to depict Insulation it works great on the Model but when I flick to the LAYOUT it is all over the place and not neatly within the Rectangle area - Could anyone advise me on this please
    2005-06
    in the upper right corner
    3,505
    Default Re: Batting
    Quote Originally Posted by Diznae View Post
    Hello there....
    We need more information, can you explain a "Layer" for "BATTING"? Do you mean a linetype for batting? (using an .shx (shape) file or maybe a font)
    Can you post a screen shot of both situations (Model and Layout)? or even better, post a sample drawing file (.dwg)?
    This is just a guess but it "could be" (if using a text style such as "standard"), that the style has an assigned height other then zero, or an annotative scale issue.
    2014-12
    3
    Default Re: Batting
    Check your LTSCALE, PSLTSCALE & MSLTSCALE settings.
    LTSCALE: Sets the global linetype scale factor.
    PSLTSCALE: Controls the linetype scaling of objects displayed in paper space viewports.
    MSLTSCALE: Scales linetypes displayed on the model tab by the annotation scale.
    Most likely, you'll need to change PSLTSCALE to a value of 1.
    Earth
    9,803
    Default Re: Batting
    ..... it works great on the Model but when I flick to the LAYOUT it is all over the place ....
    Please take your DWG file, erase everything except the linetype/hatch (whatever the object in question is) and any boundaries for it. Then SAVEAS a new file, PURGE it, then ZIP it up and attach it here.
    We are just guessing otherwise.
    R.K. McSwain | CAD Panacea |
    2005-06
    3,505
    Default Re: Batting
    The original post was in November... we haven't heard a peep from them since.
    I would be interested to know what the OP's situation is/was.
  1. Insulations Batting Line Issue
    By pinkfairy in forum Revit MEP - General
    Last Post: 2010-05-06, 11:58 PM
  2. Insulation batting interference?
    By jfg1891 in forum ACA General
    Last Post: 2009-04-27, 05:50 PM
  3. Insulation Batting in RS?
    By Dave F. in forum Revit Structure - General
    Last Post: 2007-05-14, 04:53 PM
  4. Line does not change to Batting Linetype
    By deekay2005 in forum AutoCAD General
    Last Post: 2006-07-18, 10:38 AM
  5. batting linetype in xref
    By jkipfer in forum AutoCAD General
    Last Post: 2005-04-20, 06:21 PM
