Results 1 to 10 of 19
Thread: How should I make a Preferated metal wall or ceiling?
    I could stop if I wanted to cosmickingpin's Avatar
    2004-05
    North of the 49th
    476
    Default How should I make a Preferated metal wall or ceiling?
    I should know this one, but I want to make a perforated metal panel, with actual holes, either as a system panel, independent wall type, but I don't want to go to the trouble of editing the elevation profile and add in a bunch of holes on every wall, and a surface pattern doesn't quite far enough. I know there has to be a way to handle this as a wall or panel type.
    A perforated ceiling is not as big a deal, but I am going to do some renderings for this and want something good looking for it.
    Thanks for your time.
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    Default Re: How should I make a Preferated metal wall or ceiling?
    I would suggest getting along with fill patterns and make an accurender material with the holes....it will save your model....
    2003-04
    Chino, CA
    4,756
    if you plan to use it over again, a family would be best. It will be a generic family, with instance parameters for height and width, and then a somewhat complicated parametric array of voids that would add/subtract 'holes' as the panel changed sizes.
    All AUGI, all the time J. Grouchy's Avatar
    2003-12
    Quhl Whirled
    896
    Quote Originally Posted by Scott Davis
    Can't wait for someone else to do it so I can steal it...
    All AUGI, all the time Roger Evans's Avatar
    2003-05
    South Wales UK
    828
    Haven't tried anything like this myself but would Transparency Mapping work like wot is explained in a tutorial by HJ in Revit City?
    2015-11
    Royal oak, Michigan
    1,513
    That's it Roger!!!
    Cosmic, if you are using that idling sitting big daug, then go ahead and model it, but the rendering time will increase as well as your daily routines and your file size will skyrocket. But if you want a decent rendering (not a lot of detailed shadows on the wall panel itself, but of course it will create a 2d shadow on other objects) then I would suggest adding a transparency mapping which has a black and white image showing holes. This will render, but won't show in your shaded/hidden line views, for those I suggest using a surface pattern (you already have a fill pattern for that)
    Give us a report on what you are going to do....detailed please, elaborate!!!
    I could stop if I wanted to MartyC's Avatar
    2003-07
    Brisbane, Australia
    201
    Cosmick
    I do perforated materials this way.
    1. Use a suitable surface pattern on all regular drawings for perforated surfaces
    2. Go to www.accustudio.com and download the latest material library. (note everyone should do this)
    3. Create library as described in the notes and place paths in your settings.
    4. You will then have an absolute truck-load (100's) of perforated sheets in a variety of materials. If you want a different colour, simply change it in the material editor. When rendered, the sheet functions as a perforated sheet.
    I will say it again, accustudio is an essential material and object resource for revit and Accurender, do not continue without it!
    For shaded views (not rendered) where you want see thru the holes, see the notes above........or model a void array to an extrusion maybe??!! Lotsa work!
    CheersM
    2004-05
    North of the 49th
    476
    Talking Re: How should I make a Preferated metal wall or ceiling?
    The transparency mapping thing worked out really well. I used "Chaperf-128-90.jpg" Opened it in photoshop and reversed the colors, then applied a transparency to it to the material using a Using a brushed metal as a base material. Wow that was a lot easier than I thought. I am sending the renderings now so they won't be ready till morning. Renderings was my main problem The shaded views I can get by with the surface material.
    Quote Originally Posted by MartyC
    Cosmick
    CheersM
    2003-07
    Brisbane, Australia
    201
    Hey Cosmick,
    Mate, you are still doing it the hard way! The Accustudio way is waaaay easier, and is there on your computer for ever. No messing with photo editor etc. see attachment. Just select, click and render.
    The perforated material renders as a perforated material complete with see thrrough holes. There is a selection of different %of solid to void etc., etc. There is choice of metal type, paint etc.
    If you are serious about rendering, you should have the Accustudio materials.
    And that goes for all of you OK!....just kidding
    CheersM
    2015-11
    Royal oak, Michigan
    1,513
    Hey, I agree, accustudio has done the work for you and it is a very good library to have.
    Are you IN with the crowd?
  1. Make ceiling heights in Room objects automatic
    Last Post: 2013-01-15, 01:58 AM
  2. How to make consultants' lights hide our ceiling grid?
    Last Post: 2009-07-01, 10:51 PM
  3. How do I represent a Metal Panel Wall or Metal Roofing?
    By rgecy in forum Revit Architecture - General
    Last Post: 2009-05-09, 05:35 PM
  4. New to Revit--How to make mass into ceiling plane?
    By ellis.sarahjean in forum Revit - Student Support
    Last Post: 2009-03-24, 02:44 PM
  5. How do you make a Floating Ceiling Cloud?
    By clintr in forum Revit Architecture - General
    Last Post: 2006-10-14, 01:36 AM
