Thread: Dimscale resets itself
    2004-06
    Bremerton, WA
    2
    Exclamation Dimscale resets itself
    For some reason my dimscale resets to 96 in my scaled drawings. A majority of our drawings are at 1/8" scale. But on enlarged plans I'll change the dimscale to 48 or site plans to 360. But if I exit the drawing and go back into them, the dimscale resets to 96. Is there some variable setting to fix this?
    Also the fillet command resets to 0 radius each time you go into a drawing.
    Both the dimscale & fillet problems happens to all of our workstations since upgrading to AutoCAD 2005.
    What's going on people?
    13,656
    Default Re: Dimscale resets itself
    Hi
    Are these drawing files pure AutoCAD ie.
    No Autodesk vertical products have ever worked on them.
    Quote Originally Posted by frogge
    Have I got the following correct -
    Drawing file "A" -> Fillet Radius (FilletRad) = 10
    Open Drawing file "B" -> Fillet Radius (FilletRad) = 20
    Close Drawing file "A" -> Fillet Radius (FilletRad) = 10
    Close Drawing file "B" -> Fillet Radius (FilletRad) = 20
    Open Drawing file "A" -> Fillet Radius (FilletRad) now = 0
    Open Drawing file "B" -> Fillet Radius (FilletRad) now = 0
    If that is the case, do you run any start-up utilities or Third Party Software?
    If yes, take a look at them an see if they are changing system variable FilletRad = 0 on start-up.
    Have a good one, Mike
  1. AMPOWEREDIT resets ATTDIA
    By larry.fogolin in forum AutoCAD Mechanical - General
    Last Post: 2010-05-12, 08:10 PM
  2. DIMSCALE resets to 0
    By tgross.197084 in forum AutoCAD General
    Last Post: 2009-09-25, 06:25 PM
  3. Dimscale variable resets on paste
    By timothyjturner in forum AutoLISP
    Last Post: 2007-08-03, 02:19 PM
  4. Autosave time resets itself
    By Merlin in forum AutoCAD General
    Last Post: 2006-07-18, 12:30 PM
