Hello
Is it possible to quickly put a certain block reference to each selected line end?
Hello
Yes, through programming. The only issue would be the program would insert the block on either the first point of the line, the second point of the line, or both endpoints of the line, depending on how the program is written. If it puts the block on both endpoints of each line and there are lines that connect, you'll have two blocks on top of each other. If you only want it to insert on the start point of each line, you'll have to be very careful about how each line is drawn, start point to end point.
