Thread: 3D surface bounding box
    2016-10
    2
    Default 3D surface bounding box
    Hello everyone
    I'm looking for a routine code to find the minimum bounding box around a given 3d Surface (curved in 3d dimensions).
    I searched forums for it, what I found is merely the bounding box or rectangle that is oriented in WCS coordinate system.
    What I need is the general smallest bounding box that is tangent to one of the surface faces, and contain the surface in minimum volume.
    thanks in advance.
    regards
    Wisam
    2003-07
    561
    Default Re: 3D surface bounding box
    Three was a lot of discussion about this at Cadtutor, creating a boundary of a 3 d surface, in searching terms its known as boundary of complex hull, one very smart solution was found but had a cost for program. Some others were offered but results can vary. Try www.lee-mac.com he has one solution.
  1. Bounding Box LOD's
    Last Post: 2013-11-16, 03:38 AM
  2. Room Bounding Walls NOT Bounding Rooms??
    By jkady in forum Revit Architecture - General
    Last Post: 2009-09-30, 04:57 PM
  3. How to fix non bounding rooms?!
    By Beancud in forum Revit MEP - General
    Last Post: 2009-08-05, 11:16 AM
  4. MText bounding box
    By amaser in forum VBA/COM Interop
    Last Post: 2008-09-18, 04:22 PM
  5. How to set one Bounding box to another Bounding box
    By basha_sk312 in forum VBA/COM Interop
    Last Post: 2006-02-03, 04:07 PM
