Results 1 to 10 of 13
Thread: Tool Palette Commands with Custom MText Lisp
    2017-11
    6
    Default Tool Palette Commands with Custom MText Lisp
    I am trying to create some Tools on the Tool Palette where Dtext and Mtext would be created on specific layers (One for Curb Text, One for Building Text, etc.). When I try to use it with a custom Lisp I have set for MText, it never creates the text on the correct layer; it always ends up on the current layer instead. Here is the LISP I am using:
    ; Mtext at Viewtwist rotation
    (defun c:mtr()
      (setq twang (-(/ (* (GETVAR "viewtwist") 180.0) PI))
      (initdia)
      (command "mtext" PAUSE "R" twang "J" "TC")
    Any help would be appreciated.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: Tool Palette Commands with Custom MText Lisp
    This is what I've always used
    Mtext at Viewtwist rotation as a macro:
    ^C^C_mtext;\r;(/ (* 180 (- (getvar "viewtwist"))) pi);
    Don't know if that will work any different for assigning the correct layer. Tool Palettes aren't my strong suite.
    2001-03
    Tallahassee, FL USA
    3,667
    https://knowledge.autodesk.com/suppo...fic-layer.html
    To draw an object directly in a specific layer without making the layer current
    Insert the command or object as a tool in a tool palette (dimension, hatch, circle, and so on).
    Right-click on the tool. Click Properties.
    In the Tool Properties dialog box, set the layer.
    When you draw the object using the tool in the tool palette, it will be drawn on the layer specified.
    Note: If the layer does not exist in the drawing, it will be created.
    2003-07
    559
    You need to set the layer 1st
    mtrK mtext kerb layer
    (defun c:mtrK()
    (setvar 'clayer "Kerb")
      (initdia)
    You can via a reactor actually trap command errors and convert them to commands so for me I would type mtxtk this command does not exist but I check the error look at the mtxt bit and pull the k of the end and set the correct layer, then run mtr.
    So final comment much simpler just repeat for each layer required.
    2017-11
    6
    Thank you for the replies. I tried your Command String, Tom, and it still creates the text in the current layer. I have attached an image of my Tool Properties.
    Big_Al, I would prefer to not have to create a lisp for every layer but instead just edit the Command String and have the Layer be properly set by the Tool. Am I able to do that or am I forced to set the layer in the lisp?
    2001-03
    Tallahassee, FL USA
    3,667
    Looks like it should have placed it on layer V-SITE-DECK-TEXT. What layer was it placed on?
    2017-11
    6
    Whatever the current layer is. So in the picture above the 0 layer. I thought maybe it was something wacky with the 0 layer but it behaved the same way on other layers as well. When you select the command it temporarily changes the layer to V-SITE-DECK-TEXT. But as soon as you make the text box to type in it goes back to the Current Layer.
    2003-07
    559
    Ok you will still need a button for kerb path road etc but 1 program, I would put the lisp as autoloaded on startup
    (defun mtr (curlayer / )
    (setvar 'clayer curlayer)
      (initdia)
    your buttons
    ^c^c^p(mtr "Kerb")
    ^c^c^p(mtr "Road")
    ^c^c^p(mtr "Pipe")
    if you want a keyboard option you will need another lisp as you are changing layer name. Could be as simple as a number of defuns
    (defun c:mtrk ()  (mtr "Kerb"))
    (defun c:mtrp ()  (mtr "Pipe"))
    (defun c:mtrr ()  (mtr "Road"))
    2017-11
    6
    Big-Al, the issue I am having with your button is that it changes my current layer. I want to use the tool function to add text on different layers without changing my current layer.
    2001-03
    Tallahassee, FL USA
    3,667
    Modification of BIG-AL's code should reset the current layer:
    (defun mtr (curlayer / clayer)
      (setq clayer(getvar'clayer))
      (initdia)
      (setvar 'clayer clayer)
    From home, untested!
  1. Hide text in command line when using tool palette commands
    By jpcadconsulting347236 in forum AutoLISP
    Last Post: 2014-10-28, 06:00 PM
  2. Custom Tool Palette images
    By FabriCADed in forum AutoCAD Customization
    Last Post: 2013-05-28, 01:28 PM
  3. 2012: Add Custom Commands to Tool Palette
    By Darren Allen in forum AutoCAD General
    Last Post: 2013-04-02, 04:27 PM
  4. Put sub-assemblies into a Tool Palette or the Custom Tool Catalog?
    By justin.d.ehart in forum AutoCAD Civil 3D - Corridors
    Last Post: 2007-06-05, 03:52 PM
  5. Mtext key-in or Palette Text Tool ?
    By tomdillenbeck in forum ACA General
    Last Post: 2005-05-11, 11:31 AM
